https://www.click4business-supplies.sie ... x-7600.pdf
Logic modules with graded text display for industry and building systems
The Siemens Industry Automation Division has developed new Logo! basic
devices. The logic modules of the 0BA6 series are significantly more powerful
than their predecessor models. With 200 function blocks, the memory capacity is
fifty percent larger than before, and the analog inputs have been doubled to four.
The new devices have four high-speed counters up to five kilohertz and are
equipped with Teleservice functions as well as ten menu languages. The new
separate text display tailored to the logic modules deserves special mention. It
can be connected direct to the basic device or installed up to ten meters away.
The new Logo! logic modules of the 0BA6 series are suitable for universal use in
industry and in building systems. Diverse applications are possible, ranging from lighting
controls, car washes and access controls, through aquarium systems, trash
compactors, strapping machines, axle lubrication systems on trains, and feeding
systems in cattle rearing, right up to pressure intensifiers and pumping stations.
The new text display has four lines with twelve characters each. Fifty different four-line
messages can be configured, with expanded display options such as ticker text, bar
graph or toggle parameters. Up to 32 characters per line can be stored for continuous
ticker text, for example. The display on the external text display is independent of that
on the internal text display. For example, messages relevant to operation can be
displayed on the separate text display, and service-related information can be displayed
in the control cabinet.
The new logic modules and the internal and external display are configured with the
Logo! Soft Comfort V6 standard software. New function blocks for arithmetic and pulse
width modulation expand the application options. The Teleservice function simplifies
device control and troubleshooting for service purposes. To upgrade existing systems
with earlier Logo! generations, only the basic devices have to be renewed. The installed
expansion and communication modules can be reused, as can already created
programs.
Further information can be found on the Internet at: www.siemens.com/logo
A picture accompanies this press release. You can find this picture on the Internet at:
www.siemens.com/ad-picture/1622
You can find the text on the Internet at: www.siemens.com/automation/press
Zouden half juni besdchikbaar worden....
cool
Nieuwe Siemens Logo op komst!!!
Ziet er niet slecht uit, en met zo'n display die je ergens strategisch kunt plaatsen ...
Ben alleen eens benieuwd in hoeverre de uitbreidingsmogelijkheden veranderd zijn .. Dat was vroeger toch wel DE beperkende factor ...
En ben ook eens benieuwd naar de prijs, in hoeverre die aangepast is ...
Toch iets waar velen naar kunnen uitkijken ...
het persbericht vermeldt niets van extra i/o; dus daar zullen we niet moeten op rekenen.
En ook niets inverband met koppeling van verschillende logo's. Terwijl toch vele concurrent micro-plc's dit wel hebben...
Ik denk dat ze hun echte plc's niet te veel voor de voeten willen lopen.
Maar toch een mooie upgrade!
200 functieblokken ipv 130! Die 130 zit toch redelijk snel vool hoor als je wat intelligente dingetjes programmeert. Ik Dat 200 beter match met de i/o mogelijkheden (voor het domotica geval dan toch)
Ja, 't zou waarschijnlijk teveel gevraagd zijn, van ze te kunnen uitbreiden tot en met, waar anders met die s7's blijven hé ?
Ik dacht trouwens ook van die extra display ergens centraal te kunnen monteren in een leefruimte, maar ik zie dat het met een seriele kabel aan de zijkant moet aangesloten worden, wat dat al niet makkelijk maakt !
Eigenlijk heb je daar wel een punt, ik snap dan ook niet, waarom ze daar niets financieel haalbaar voor voorzien EN dat tegelijk ook waardig is om in een leefruimte op te hangen of in te bouwen ... Al was het een soort minitouchscreentje voor in een 7module blok van bticino ...
