RF receiver for the Visonic Powermax
bwired
Post by bwired »
Hi All,
I have been testing the first beta version of the RFXCOM Receiver for the VISONIC Powermax by Rfxcom http://www.rfxcom.com With the VISONIC RF Receiver it's possible to receive all the sensors of the Visonic Powermax. This is something which was on my wishlist for a long time . Supported sensors are:
MCT-302 Doorsensor
MCT-423 Smoke detectors
MCM-140 Remote Keypad
MCT-100 Universal transmitter
MCT-234 Wireless Keyfob
MCT-302 Doorsensor
K-940 MCW PIR
MCT-501 Glass break detector
MCT-550 Flood Detector
Next K9-85 MCW Pir
MKP-150 LCD Panel
I have a lot of Visonic sensors in the Bwired house which status can be picked up now by as well the Visonic control panel as my own homeautomation system. So for example the PIR's in my house I can also use for switching on lights etc. The receiver is housed in a small USB box which can hold two receivers. So I added a X10 receiver as well. So with just one Small USB box I can receive X10 RF from all X10 wireless devices on 433.92MHZ or 310MHZ as well all the Visonic devices on 868, 315 or 433.92MHZ. The power for the receiver comes over the USB cable, so no extra power supply is needed.
I have tested Both devices (Visonic RF / X10 RF) on range an accuracy. I must say the Visonic receiver is reveicing the signals from In and even around my house perfecty on a small wire antenne of 10cm. The X10 receiver comes with a little antenna. Also the X10 receiver is capable of receiving every X10 RF device in my house (believe me I have a lot ) This is something of what my current W800RF32 with antenna is not capable of! With the W800RF I frequently miss a status, specially the dark on or -off status from the MS13a which is only send once.
What is also nice for homeseer users is that the Visonic/X10 receiver is working perfectly along with the Homeseer plugin of the W800RF32!
Im not using Homeseer so I wrote my own driver for my Bwired Home Control system. From my 25 Visonic devices I have put a couple online
check Bwired Devices http://www.bwired.nl/devices.asp and sort on type then you find the Powermax devices. In a couple of weeks all the devices will come online.
Regards Pieter
www.bwired.nl
Domotica Home Automation, a realtime home in the netherlands using X10 A10 Xanura wireless weatherstation and streaming Mobotix and Axis webcams. Harrison electrische gordijnrail.
simonjo
Post by simonjo »
Hoi Pieter,
Ik had al van je site gehoord en heb hem ook bekeken, dit is echt wel het resultaat van geduldig volgehouden werk... zeer knap, zowel technisch als qua layout.
De vragen die bij mij opkomen zijn volgende:
- heb je een richtprijs voor die sensoren en receiver
- welke programmeertaal gebruik je voor je eigen SW
mvg, Jo
